跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Do iPhone 7’s naturally run hot?
I purchased a used iPhone 7 and replaced the cracked screen with a new one. It is in cosmetically almost mint condition now (housing was in very good condition), however have noticed that when 20Watt fast charging it and during use it can get quite hot near the logic board. The device hasn’t been water damaged (indicator is white) and the logic board is in visibly perfect condition with no signs of logic board repairs, and all parts appear to be Apple Original. Any ideas? I have another 7 as a spare that can also get quite hot when playing games so I don’t know if it is just a thing with the 7’s?! Thanks (:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
iPhone 7 doesn’t support fast charging, the best it can do is about 7.5-10w.
Since we can’t be sure of your subjective experience of temperature, all we can do is ask you to get a known good iPhone 7 to compare, if they behave the same consistently, then it is normal.
这个答案有帮助吗?
得分 2
1条评论:
Okay cool - I will try it against another 7 or 7 Plus if I can’t find one, and will use standard changing brick and see if that works better. Thanks!
完成的
添加一条评论
添加你的答案
TmG 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 38
