跳转到主内容
An 18.4" table top tablet/tv hybrid with a built-in kickstand and handle, designed for high-quality video and media streaming.
Tablet not charging with new cord
I bought a new charger thinking this was going to fix my issue. Nope. Bought new correct charger. Tablet turns on BUT STAYS AT ZERO :(
Kept it on for hours on charger and still stayed at 0%.
Help! I love my tablet!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @overworkednurse ,
Does the tablet turn on and stay on (for how long?) without the charger being connected?
完成的
Nope. It will shut right off.
完成的
That’s why I thought I needed a new cord. With the old one it would even stay on at all.
完成的
添加一条评论
1个答案
最有帮助的答案
Maybe I phrased it wrong.
Does the tablet show that the charger is connected, even though the battery is apparently not being charged?
If not then I’m wondering if there is a problem with the charging connector (supplier example only) in the tablet.
Here’s an image taken from the ifixit Samsung Galaxy View Motherboard Replacement guide that shows where it is located on the motherboard. The guide will help to gain access to the connector so that it can be disconnected from the motherboard and tested to make sure that there is continuity through the connector to the cable plug that is attached to it.
(click on image to enlarge for better viewing)
If it does show that the charger is connected and if it won’t stay on or even turn on using the battery only I’m wondering if there is a problem with the battery.
Here’s the ifixit Samsung Galaxy View Battery Replacement guide which will help you to remove / replace the battery.
Replacement batteries aren’t that cheap though.
Search online for Samsung Galaxy View SM-T670 battery (if this is your model number) to get results for suppliers of the part.
Samsung Galaxy View Battery图片
指南
难度:
中等
15 - 25 minutes
Samsung Galaxy View Motherboard图片
指南
难度:
中等
20 - 30 minutes
这个答案有帮助吗?
得分 1
13条评论:
The tablet does show that it is charging, I left it on all night. I checked it this morning and it is at 1%. So I do believe it might be the battery.
完成的
Roughly how expensive are the batteries?
完成的
@overworkednurse
You may get different results to me because of location so as suggested search for "Samsung Galaxy View SM-T670 battery"
Here is just one to give an idea. Click on "Available from these sellers".
完成的
I was just on Amazon looking so thanks for the short cut. Will check my device number to make sure I get the right one. The instructions don’t look to hard. I think I can handle 7 steps. Thanks for the advice.
完成的
Is there a way to check the model number without having to take the device apart i.e. settings perhaps?
完成的
显示更多的8条评论
添加一条评论
添加你的答案
Tiffany 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 997
