跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 控制器的维修指南和信息。
Why don't my S series buttons work?
My S series buttons on my right joycon aren’t sensed by the controller, but the Sync button and the Player LEDs still work. Worryingly, when I take it apart, the buttons do work. It only fails when the joycons are assembled and the ribbon cable is bent to fit into the case.
Help me iFixit, you’re my only hope.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
It’s definitely wierd but is that really the ribbon cable that cause the issue ? it could also be due to a contact between two parts that shouldent be connected.
Mayby try to look at a case replacement tutorial to see if you put it back correctly.
Here’s an example :
Nintendo Switch Left Joy-Con Shell Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 0
1条评论:
I guess it is possible, but I've put it together just fine several times before this, and it would work just fine until recently. It also wasn't acting the same when disassembled as the one in the left joycon. I ended up buying a new board to replace it, and that works just fine now and has different colors of LEDs.
完成的
添加一条评论
添加你的答案
Rosetta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 92
