跳转到主内容
加入维修社区 - 创建账户
GameCube 是任天堂的第四代家用游戏主机。维修很简单,仅需常用工具即可完成。
Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
完成的
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
这个答案有帮助吗?
得分 1
添加一条评论
How about check to see if the video connector has a bended pins or damaged pins?
这个答案有帮助吗?
得分 0
1条评论:
There at no bent or damaged pins
完成的
添加一条评论
添加你的答案
David Lank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 93
总计 10,977
