跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Will the iPhone 4S camera module work in an iPhone 4?
I was wondering whether anyone had any idea as to whether the iPhone 4S camera would work if transplanted into an iPhone 4?
I had. Look at the teardowns and physically they look the same in size and connection, however do we have any info whether the newer camera module would be even recognised by the former model iPhone?
Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
the camera won't fit
count the pins and you will see that it won't fit
这个答案有帮助吗?
得分 6
1条评论:
You're right! One has 28 pins, the other has 32. Should have counted them before asking, lol
完成的
添加一条评论
I'm not sure how it's possible for your 4s camera module to work in your 4 when there are a difference in conn pin count.
这个答案有帮助吗?
得分 1
添加一条评论
I am not 100% sure, however if it is like the 3G and 3GS models it will not fit. For the 3G/S models there are two different camera housing holes (3G - Circle / 3GS - Square)
I haven't done any research regarding this and others are more than welcome to correct me, however knowing apple, they will have put in some counter measures in place to stop 4S camera's going into a 4 model.
这个答案有帮助吗?
得分 0
添加一条评论
i have a 4s camera in my iphone 4 and it works just fine.
这个答案有帮助吗?
得分 0
1条评论:
Please help me to fit 4s camera on 4 , nick
完成的
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 14,179
