跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Camera not working after display replacement
Hi, I’ve just replaced my LCD screen assembly, making sure the battery was disconnected while I did this. However, the camera does not work even though the rest of the screen works perfectly. The suppliers for the replacement assembly assured me the camera was tested before it was sold to me. Please help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi, I faced a similar problem after assembly replacement for A1502, I got it done from technician (not service centre who also sold me the same) , camera did work for first time after reboot, for around 3-4 days, then ended up showing no camera connected for another 2-3 days, then again worked few days later. Right now it has again stopped to show up on system report and shows error" not connected to camera "while on apps.. Apparently I visited the technician again he cheked for the assembly in his system.
Surprisingly, Camera worked without fail for several times after multiple restarts also. Probably the assembly is not faulty, but what for I am facing the issue...how can I fix it? The tech guy says my motherboard is screwed up or something...please help me...
完成的
添加一条评论
3个答案
最有帮助的答案
Sadly, you either have a bad connection or have bad display assembly. Here’s a breakdown of the display ribbon cables:
Photo credit: @just1ed www.macplus.sg
See if reseating the cable fixes things other wise you’ll need to get a exchange.
这个答案有帮助吗?
得分 2
添加一条评论
While my Mac experience is limited, my first thought would be to check if the device is showing up within their version of Windows’ Device Manager. If it’s in there, the machine should at least be acknowledging that it exists and is connected, if not, the machine is likely not recognizing it as physically connected and I would suspect that if the camera is indeed not defective, then it may have either a loose connection or was not connected correctly again during the recent screen replacement.
Were the entirety of these steps followed during the screen replacement, especially those related to disconnecting/reconnecting the antenna and cabling leading to the screen? 2017款MacBook Pro 13英寸带触控栏版本屏幕更换指南
这个答案有帮助吗?
得分 0
添加一条评论
The screen may not be defective. The touchbar model (A1706) and the function key model (A1708) should have interchangeable screens. Have you confirmed that the board is not the problem? Was the previous screen webcam working? I have seen them not work from both ends. When it comes to screens the eee code is everything. Its the only 100% way to guarantee compatibility.
这个答案有帮助吗?
得分 0
1条评论:
@iseanlove - The system is the function key model and it’s display assembly is physically different than the TouchBar models.
完成的
添加一条评论
添加你的答案
Zac Dawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 5,481
