跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Magsafe led doesn't light up. Laptop won't charge
A few months ago the LED on my MagSafe charger suddenly went out.
The battery would no longer take a charge. I tested out multiple chargers still to no avail. This week, I finally got around to replacing the MagSafe and when I went to charge it up, still nothing.
Does anyone have any ideas on what could be happening here? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
Is this a 2008 MBP or a 2020?
完成的
@mayer not quite sure. I dont know what MBP is
完成的
How about plugging in your systems S/N here to be sure! EveryMac - Lookup Let us know what it told you.
完成的
@danj
MacBook Pro 15-Inch "Core i7" 2.5 Mid-2015 (DG)
2.5 GHz Core i7 (I7-4870HQ)
Intro. May 19, 2015 Disc. October 27, 2016
Order MJLT2LL/A
Model A1398 (EMC 2910)
Family Retina Mid-2015 15"
ID MacBookPro11,5
RAM 16 GB
VRAM 2 GB*
Storage 512 GB SSD Optical None*
完成的
You talk about replacing the MagSafe. Do you mean the charger or the MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board?
完成的
显示更多的1条评论
添加一条评论
1个答案
You’ll need to pop the logic board out and inspect the SMC logic for damage MacBook Pro 15‘’Retina显示器2015年中期主板交换
这个答案有帮助吗?
得分 0
2条评论:
@danj thanks for your answer. Before I tear my laptop apart again. What type of damage should I be looking for? What makes you think the smc logic is causing this problem?
完成的
@Evan R - What controls the MagSafe LED and the charging of your battery? The one wire comm link to the charger from the SMC.
You tried a few chargers and replace the DC-In board. That only leaves the logic board (SMC logic on it)
完成的
添加一条评论
添加你的答案
Evan R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 137
