跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1200 个问题 查看全部
How to spot fake iPhone X Screen
i have bought a iPhone X Screen which is described as 100% original, refurbished.
I got the screen here but there is a stamp on it which I have seen at another fake displays before (I think !).
The Stamp is like “亿” (translator says “100 Million“) and there is another stamp which is very hard to see.
I don’t think that apple uses stamps on their screens.
How else is it possible to spot if it is fake or not?
Unfortunately I already disposed my broken original display so I got o comparison.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
Some companies put their own stamps on their supplied displays, or it could be refurbished, so has an original LCD but a new frame.
You can usually tell if it is a lower quality LCD (or even hard OLED) display by looking at the bezels. The bezels are usually thicker as both technologies aren’t flexible. Also, in cheaper screens, the bottom bezel can be significantly thicker. Look at the display lines for clean bezel/LCD lines,
When the display is turned on make sure it is bright, has good viewing angles (tilt iPhone side to side), and touch works well.
Another big tell is the Screens display to frame plastic bezel thickness. Displays that have a thicker plastic buffer between the screen and lcd glass (after installed with adhesive) are usually aftermarket, or have an aftermarket frame at least.
Search for a genuine display back-print and see if it matches this display as well!
Hope this helps - as long as it is a good quality Soft OLED display then the replacement screen should look good!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brother 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 31
总计 2,588
