跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Why does replacement home button only double tap and nothing else?
i recently had a home button that didn’t work so i bought a new one and it doesn’t work, its connected and it doesn’t even click. but it does double tap.
ALSO:
i have recently found out that the backplate of the replacement home button has fell of. id this the reason why it doesn’t work? and how can i fix it
https://www.amazon.co.uk/dp/B07ZD6NC1Y?r...
have i been scammed or lied to? or is it something else
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First of all, don’t buy parts on Amazon
Second, it’s a YF button, it only works with taps and doesn’t really do an original click, like try just tapping it once and it should act normal
这个答案有帮助吗?
得分 0
2条评论:
it doesn't act like "normal" after i tapped it once. what should i do ??
完成的
Return it and take it to a local repair tech
完成的
添加一条评论
添加你的答案
matthew einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 67
