跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Can the battery remain connected when replacing screen adhesive?
Hi everyone,
On every each tutorial I come across to replace screen or anything else I noticed that the battery must be disconnected before unplugging the screen or anything else.
Hence I don’t quite understand why can the battery can remain connected while the screen is unplugged when replace the screen adhesive? Am I missing something? What should I beware of when doing this?
Thank you very much !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It is the plunging and unplugging of connectors that can blow the fuses that are soldered on the logic board. So it is ok to have the battery plugged in while you are not plugging or unplugging a connector.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much :)
So I just need to be careful that the connectors are right in front of their slot when I plug them back in? And obviously unplugged them gently.
完成的
添加一条评论
添加你的答案
KasDing 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 30
