跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Volume and Mute Button Depth is Off
I'm in the midst of reassembling my 3GS after replacing a cracked housing, and the volume and mute buttons don't seem to be protruding far enough after putting that assembly in.
I've tried and retried 10 times, with the same results each time. They both sit almost flush.
So I'm wondering - is this normal? Do they get pushed out to the correct depth after everything else is in the phone and is pushing on them?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Try a small file to make the opening bigger
完成的
添加一条评论
2个答案
已选择的解决方案
I ended up answering my own question through testing. The answer is no.
I popped the bezel and assembly back into the old housing to see, and the buttons functioned perfectly.
So if any of you end up here with the same problem, it's because the unofficial housing is off spec.
这个答案有帮助吗?
得分 1
添加一条评论
The after market casings will work. You just have to shim up the Mute, Volume, & Power buttons. Black electrical tape works great.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Rovick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 864
