跳转到主内容
加入维修社区 - 创建账户
Infinity v2 10.1 英寸平板电脑于 2014 年推出,运行 Android 操作系统。
How to I do a factory reset, I tried the power and the +volume
I tried to reset n unable to change the password how do I do a factory reset
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
To reset the device, there is a reset button located on the bottom of the device located next to the mic. To activate the button you must stick a pin into the hole where the reset button is located.
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
Did you do it this way?
Press and hold Volume + button and the Power button at the same time.
The tablet’s screen should turn on.
When it does release the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
这个答案有帮助吗?
得分 2
2条评论:
Nothing happened still won't turn on
完成的
@jamesdewey35486
Does the tablet show that it is charging when the charger is connected?
完成的
添加一条评论
添加你的答案
anu harigyan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 2,873
