跳转到主内容
加入维修社区 - 创建账户
小米 9 是小米于 2019 年 2 月发布的中端智能手机。它配备 6.39 英寸 Super AMOLED 显示屏、4800 万像素主摄像头、1600 万像素超广角镜头和 1200 万像素长焦镜头、屏下指纹识别器,以及支持无线快充的 3300 mAh 电池。
Fingerprint not working after screen replacement
Hey guys
have replaced the screen (whole unit with frame) on this Xiaomi Mi 9
afterwards the fingerprint Sensor did not work properly. It hardly Scans the initial fingerprint but won’t unlock the phone with it or allow any other fingerprint functions.
I have already removed it and replaced it again. as it is embedded into the Display Unit I Wonder if this is a problem concerning the display unit or the fingerprint scanner itself.
if it is the fingerprint scanner, would it even be possible to replace it or is it like on iPhones „married“ to the motherboard?
would appreciate your support guys
keep fixing
peace
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
I feel like it has to do with the screen. Where did you get the part?
完成的
Did you fix it? Have the same issue after my screen replacement
完成的
I have the same problem here.
完成的
添加一条评论
5个答案
Exactly the same here.
Bought Frame + Display on ebay (Germany). Everything works perfect except the fingerprint sensor.
"Learning" a finger is hard. Only every 10th scan is recognized. Other 9 fail with messages like "too fast" or "dirty sensor".
Unlock has two different behaviors:
1) On ambient display: It never works (which previously did). The sensor "scans" for around 300 milliseconds and fails. With the old display it took the same amount of time but it worked.
2) After pressing power button: It takes about 1 second (which is a really long time) for the scan to be completed but works most times (9 out of 10). Previously it worked much faster.
/edit
Just found out that it does NOT work properly in the “power on button” state. After 1 second the device gets unlocked, BUT it also gets unlocked with unknown fingers! Maybe it focusses something in the display?
这个答案有帮助吗?
得分 0
1条评论:
I highly doubt it's the phone's fault, but rather a bad quality part. This is why you have errors
完成的
添加一条评论
Apparently the latest software blocks the figure print replacement from working.
这个答案有帮助吗?
得分 0
添加一条评论
I’d first check if the fingerprint sensor or the scan hole are dirty, and clean them. Afterwards, try erasing all the fingerprints and re-adding them. It’s possible that a software update started to pair displays to the motherboard, so one way of fixing this would be using a custom ROM. Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
Late update: just had a client with a similar problem.
Turns out the fingerprint sensor is really sensitive to the positioning, so if you bent one of the plastic positioning pins even slightly, it will register the first few scans, but fail after. I'd suggest getting a new one if that's an option, as well as cleaning the glue residue, then adhering the new one in place with the right thickness of new adhesive tape (I think one or two layers of a B-7010 type double-sided should do, does require some trying however).
完成的
添加一条评论
https://www.youtube.com/watch?v=9jKmbfP2...
This is work propertly :)
这个答案有帮助吗?
得分 0
添加一条评论
Hi all,
I have recently replaced the display of the Mi 9 (from Aliexpress).
After installation the fingerprint worked and when I tried again after the factory reset the input was failing and after multiple tries, I was able to add the fingerprint.
One way I overcame the fingerprint unlock problem is by adding the same finger multiple times.
I tried to do the calibration through CIT but I'm getting Auto_Exposure test fail.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimmy industries 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 45
总计 8,970
