跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
294 个问题 查看全部
After SSD replacement, no chime or turning on at all
I recently replaced the fusion drive in my 2017 5k iMac with an SSD, following the iFixit guide. I’ve done this previously on a 2012 21.5 iMac which went off without a hitch.
Unfortunately, after putting the screen back on, there’s no chime, no boot - zilch. Any ideas as to where to start? During the process, nothing was bumped, I didn’t move any logic board parts (just the left speaker slightly to the left to get to the 3.5 HDD bracket).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Perhaps you need to reformat the drive?
这个答案有帮助吗?
得分 0
添加一条评论
It most likely is trying to boot into the remaining SSD part of the the fusion drive which will not work nor will recovery drive. These will have been damaged as HD has been replaced bets thing is to get access to a Usb install drive and look at drives reformat and install on new drive
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ash Pegram 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 55
