when I pour water in my radiator it runs to mh crackcase drain plug
My problem is when i pour water in my radiator it runs to mh crackcase drain plug non stop flow.its been hydrolocked..still starts with a loid rattle noise…can anybody help
Most probable is either a failed gasket or a cracked block. Water its heavier than oil, so it will go to the bottom of the drain pan.
这个答案有帮助吗?
Could it be a oil coolier line
That is a symptom not the problem. Sounds like a blown head gasket at best and at worst a cracked block or maybe a thrown rod that has resulted in a compromised engine water jacket. You could start with removing cylinder head(s) to see if the problem is obviously limited to a head gasket issue. Either way this will be a major expense to repair or replace the engine in all probability. Good luck sir.
这个答案有帮助吗?
That is fast if its a blown head gasket it but could be a cracked block i hope..if i could fix it then i think it will come right.it still seems to run on all 8 cylinders jus a rattle and not much oil flowing to the top
These vehicles come with either a v6 or an i4 engine only as manufactured. If it pours out the drain plug as fast as you pour it in, then the engine is likely unrepairable.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 71
