跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Replacing BGA LPDDR3 RAM chips
I have a late 2014 mac mini with 4GB RAM. I already replaced HDD with SSD but some apps, even World of Warcraft can cause the system to hit swap. I use it as a secondary device for macOS experiments and alike from time to time… so I’m thinking about doing a bit risky mod - replacing existing Samsung K4E8E304EE-EGCE 8 Gb x 4 with chips of higher capacity and 178FBGA package - like K4E6E304EE-EGCE which are 16Gb.
Is it technically possible or is there something that would prevent such swap from working?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thank you your information This Topic help me too much for the solve problem
Welcome to Batman999
完成的
<br /><a href="http://batman999.com/">สล็อตออนไลน์บนมือถือ</a><br /><br />
<br /><a href="http://batman999.com/">เกมส์สล็อต</a><br /><br />
<br /><a href="http://batman999.com/">สล็อตบนมือถือ</a><br /><br />
完成的
添加一条评论
1个答案
已选择的解决方案
I would just get a replacement logic board which has the max memory this system can support Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board
Replacing the the chips is very risky! You need the proper tools and skills, you also need the schematics and board views so you can adjust the resistors so the chips are recognized. Without the documentation you’ll have a hard time figuring it out.
If you don’t have the tools and have never worked with BGA chips this would be a foolhardy endeavor.
Replace a logic board (motherboard) compatible with the Mac mini (A1347, model MGEM2LL/A) small desktop computer. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
$199.99
这个答案有帮助吗?
得分 2
2条评论:
@danj Yep - you need the schematic to reconfigure the resistor so it knows if the rMBP/MBA provides a clue.
It's not as simple and magical as people make it out to be - this is not a job for the first timer!
完成的
Thanks, I was afraid it's more than just the LPDDR chips :) I'll see what's the local board market.
完成的
添加一条评论
添加你的答案
Piotr 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 38
总计 1,482
