跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
Is it possible to upgrade from 512 MB to 1GB of ram?
Would it be possible to upgrade the 4S ram by swapping chips? Is there even a compatible 1GB chip available? Do you think the hardware would then recognize a bigger chip or would it cause problems?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
If your asking, then you probably can't and shouldn't do it.
完成的
It is a good question, but not possible:-)
完成的
添加一条评论
3个答案
已选择的解决方案
Unfortunately, the RAM is integrated into the logic board, so upgrading the RAM would be extremely difficult if not impossible.
这个答案有帮助吗?
得分 6
3条评论:
Yeah, I know about it being part of the logic board, but I was just wondering if it would be possible if one was super careful with soldering (i.e. using a microscope) if the contact arrangement was the same.
完成的
"super careful" ? - are you aware that you have to solder stuff like that with infrared- or hot-air soldering stations????
完成的
Just check on here http://www.circuitrework.com/guides/7-0.... and see what you think. with a medium grade station like this http://www.hakkousa.com/detail.asp?CID=5... and lots of practice , it might be possible. Oh yes, where are you going to get the the RAM from?The IC on the logic board for the 4s might not fit the 4 circuit board. So you will also need the datasheets for both of the IC's to make sure that the internal 'layout' is the same. You see, to many economical and logistics head aches to even try for one phone...so go with what Matt and markus are saying.....;-)
完成的
添加一条评论
Upgrading RAM is not possible on the 4S, even with a rework station and the knowlage to use it. The phone's RAM is embedded in the A5 "System on a Chip" CPU, It is not on it's own individual chip. This makes upgrading RAM inpossible.
这个答案有帮助吗?
得分 2
添加一条评论
My touch screen has a semi flex - broken. If the phone is switched on without connected touch flex and then i punch my phone to reconnect the flex, my phone recognizes it and makes it work .
therefore means that android somehow works with a " plug and play" system
That would mean that if I change the ram chip , it can recognize up to where the chip responsible for administering the ram can handle it
这个答案有帮助吗?
得分 0
1条评论:
I do not follow you are all. Are you talking about an iPhone? Are you talking about memory that is plug and play? Do you realize how the memory is installed on the logic board?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 4,088
