跳转到主内容
New SSD won’t show as an option in reinstal
I’ve replaced my old hard drive with a new Samsung SSD. I had backed up my previous drive and just did an uinbox and replaced. When I open recovery it won’t show up as an option when trying to reinstall my backup or install OSX. When I check disk utility it shows up as my internal device. What could I do? Thank you in advance for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is the new drive backward compatible to SATA II (3.0 Gb/s)?
Did you first use Disk Utilities to format the drive GUID?
这个答案有帮助吗?
得分 2
2条评论:
Thank you for responding.
I did not format it in Disk Utility.
As I start to do that now and click Erase to format, I’m given many options for Format and Scheme. The default choices for both were Format: Mac OS Extended (Journaled) and Scheme: GUID Partition Map.
Would it be best to leave those?
完成的
what system are you trying to install
完成的
添加一条评论
添加你的答案
CampM 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33
