跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Status led in iPhone?
In step 10 of the teardown you say, "What appears to be the ambient light sensor and status LED comes off the display assembly."
Could you explain what the "status led" is? Is it equivalent to a notification led?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
@markus weiher, Do you have any idea what the infrared led is used for?
完成的
添加一条评论
3个答案
已选择的解决方案
i want to bring a little bit light into the darkness - the 4s has no status led.
the dark led is an infrared emitting led!
EDIT: thats really funny - is it to hard to understand ? - it's not a notification led.
but to show it to you, here comes a pretty bad picture of it
since infrared light is not vsible - we can't see it
but you can make it visible with a digital camera - pint at the earpiece speaker and wake up the 4gs - et voila - the infrared light is "visible"
这个答案有帮助吗?
得分 4
6条评论:
I think they mistook the proximity sensor, which would appear like an LED and sensor pair.
完成的
Nope... proximity sensor and the light sensor are seperate.. To me it seems like a Status LED.. Its quite unclear yet!
完成的
I questioned that too because now there is a new opening in the casing next to the proximity sensor and ambient light, might be a status led
完成的
I hope it's a notification LED.
完成的
youre saying its infrared? how can you be sure? just curious...
完成的
显示更多的1条评论
添加一条评论
Your "Dark LED" is the Proximity Sensor. It is shooting out IR which bounces back and hits a receiver which tells the phone when it is next to your face. That shuts off the screen so you dont inadvertently touch and trigger actions on the screen. Right next to it is an ambient light sensor that the phone uses to automatically control the brightness of the screen to preserve battery life. My question is just over from there there is another hole in the case with an unknown function. It can be barely seen from the front of a black 4S and is invisible due to being painted on a white iphone 4s. The round hole is plainly visible in the teardown and is not in any of the previous phones.
这个答案有帮助吗?
得分 2
2条评论:
I'm curious as to what the sensor does because my case covers it up. Is it for the new camera system or something?
完成的
scottalanwhite ,Check the answer given by Barry Gilbert.
完成的
添加一条评论
I understand what Barry is saying. I know where the ambient light/proximity sensors are. There is a new hole just to the left of these. What does this do? See the picture below.
这个答案有帮助吗?
得分 0
1条评论:
behind that particular hole is the ambient light sensor (tried it with a led flashlight)
完成的
添加一条评论
添加你的答案
Mikael Johansson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 8
总计 4,265
