跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
DFU Update/Restore doesn't solve the problem
Hi,
I have an iPhone X to try to help a friend get running again. It is constantly rebooting (Apple logo, black, Apple logo, rinse and repeat). I've manually restarted the phone several times and have also gone into DFU mode to Update, Restore, Update and Restore. The process seems to work (I'm assuming so) since the update goes through on the Mac and on the iPhone (seeing progress), then it will reboot. It's back to the stuck power cycling. Any ideas, or is it time to repair/punt and get a new phone?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try to update/restore your idevice without the screen, frontcam and backcam connected to logic board.
Only battery and dockconnector connected to logic board and then connect to itunes and update/restore your iphone.
这个答案有帮助吗?
得分 0
3条评论:
Thanks! Got the phone back online after restore.
完成的
Apparrently, Face ID was coming into play during the reboot. Interesting.
Ensure that all of that still works, after using that ‘disconnected camera’ technique above.
I am very interested because my Xs has a failing Face ID, possibly because of a drop shock to the phone - works perfect otherwise. I’m wondering if an array cable came loose.
Thx!
完成的
Shed loads of comments about removing the ear speaker ribbon to boot a boot looping phone. First thing that should be tried.
完成的
添加一条评论
添加你的答案
scottbookout 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
