跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Broken Bluetooth antenna after battery install
I just successfully completed the battery replacement on my Macbook 12” Early 2015. Unfortunately, I broke the Bluetooth antenna socket when trying to disconnect the Left Speaker. The sound on both sides of the speaker still work. Is the only way to fix this to replace the circuit board? Is there any way to soldier the socket back onto the circuit board?
The issue I ran into was at Step 29 of the following guide:
“The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.”
Retina MacBook 2015 Left Speaker Replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Can you post a nice clear picture of the logic board area as well as there mating surface of the connector which is now fixed to the cable 在已经存在的问题里加入图片
完成的
Thanks, Dan. I just uploaded a photo - prior to the damage. Unfortunately, I wasn't thinking and forgot to take a picture of the damage before closing back up the Macbook.
A portion of the socket is still attached to the antenna connector. There is nothing on the circuit board anymore. I did save a very tiny "nub" piece that appears to have been a part of the socket.
完成的
Does the Bluetooth work? Have you tested it?
完成的
Sorry, I should have been clearer on that. The Bluetooth itself can be turned 'on' and 'off' in Mac OS, but I have not been able to make any connections to my bluetooth devices. I did try to AirDrop a URL from my iPhone to Macbook, which was successful. But I read that that AirDrop can also use WIFI instead?
完成的
添加一条评论
4个答案
最有帮助的答案
The picture helped! You are lucky! I had suspected you had yanked off the socket from the logic board. Instead you pulled the cable off the connector end.
Think of it this way… Your bedroom light is plugged in the wall outlet but you didn’t break the wall outlet you pulled the cable off the plug that goes into the wall outlet! (can you imagine the sparks flying!) So, we still have to remove the broken plug part out of the outlet and then we need to replace the lamps cord with a new connector!
So going back to your MacBook…
Here we need to carefully remove the broken connector on the logic board without breaking off the mating connector mounted on the logic board. You’ll also need to replace the speaker unit MacBook 12" Retina (Early 2015-2017) Left Speaker if I got it right.
Replace a left speaker compatible with the Early 2015 to 2017 model A1534 MacBook 12" Retina laptop. Fix issues with sound output. Includes one of two antennas. Part #923-00410, 821-1962.图片
产品
$14.99
这个答案有帮助吗?
得分 2
3条评论:
Unfortunately, I think it was the worst case scenario. That picture was actually the “before” picture before I removed the connections. The socket came off of the logic board and part of it is still connected to the connector. I think I wiggled it slightly side-to-side and it came undone. I found a company out of Alabama that repairs logic boards, but it’s about $300-400 for the repair (if it’s successful). A brand new logic board is about $400-500. A new MacBook Air is around $1,000.
So at this point, I’m probably either going to A) just live with the Bluetooth not functioning or B) sell the laptop “as-is” for someone who doesn’t mind no Bluetooth or for parts.
完成的
@Adrian Vann - Sorry to hear that ;-{
Don't forget to accept the answer - Thanks!
完成的
I ended up here because of the same situation. New battery, no bluetooth. I need to be more careful next time.
完成的
添加一条评论
Hey @simonm62936 & @adrianvann,
This still can be fixed. If the actual socket on the motherboard is broken, you can strip a little bit of the wire off the cable and then solder it on. Be careful not to spend too much time touching the motherboard with the tip otherwise you really will be in for a new motherboard. Simon, might you be able to send a picture of what happened to you?
Hope this helps.
Falcon16
这个答案有帮助吗?
得分 1
5条评论:
Yes! I’m away from the machine but will do that asap. Basically the socket has lifted cleanly off the motherboard and is still attached to the cable.
完成的
And thanks for your help!
完成的
Does that answer your question?
If it does, please support me to help others by uprating my answer and pressing the button that says I answered your question. This also marked the thread as answered so other volunteers will know.
Thanks!
--Falcon16
完成的
posted pix for you to see @Falcon 16
完成的
@falcon16 posted pix for you to see
完成的
添加一条评论
I'm here too. Is there any way top fix it or is it a case of no bluetooth or throw the laptop away?
这个答案有帮助吗?
得分 0
添加一条评论
Hi @falcon16 @adrianvann - attached are pics of the board which no longer has the socket attached. It's come clean off. And the lead which now has the detached socket stuck to the end of it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adrian Vann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 649
