Repair guides for the Surface Book 2 15", The 15 inch version of the hybrid laptop/tablet manufactured by Microsoft. This device was released in November 2017.
Daryl Valle you removed the screen from where and how/why? A white bar usually indicates that your panel does not receive any video signal. Bad cable, torn ribbon etc. would be the most likely cause for this.
Yea, there isn't any obvious damage., the flex cables that attach to the logic board look pristine, if any damage occured it was to the cables on the display itself. While it looks like I hit them with the jimmy they don't look creased/frayed/cut in anyway but they're delicate, so I guess I might need a new panel and not just cables.
由 oldturkey03 完成的
@oldturkey03 The SSD needed to be replaced. Should I buy the video cables before buying the LCD?
由 Daryl Valle 完成的
Daryl Valle take a look at those cables/connectors first and see if you can make out any obvious damage.
由 oldturkey03 完成的
由 Daryl Valle 完成的
