跳转到主内容
Not displaying on monitor
Just build my first gaming PC when tried turning on nothing comes on the screen but it's sometimes it says reboot and select proper boot device. I have spend so much money on my gaming PC and it's not working now I'm so depressed so if someone can help that would be great.
B550m-hdv
Ryzen 5 3500x
Rtx 3070
600w psu.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Raman multani this "it says reboot and select proper boot device" sounds like your computer can't find an OS or the HDD. You checked your RAM? Reseated it as well? What have you checked? Can you get into your BIOS?
完成的
Hey thanks for the reply sometimes i get into the bios but sometimes not it usually not work all the time
完成的
@Raman multani that would mean it is not a video issue but a processing issue. Make sure everything is properly wired, processor properly seated, Ram modules properly seated etc. Double check your HDD connection as well as function. It is a new HDD or SSD depends on what you are using?
完成的
@oldturkey03 it's a new ssd brand new build. So when I'm shorting the power pins using a screwdriver sometimes it shows a display but most of the time it wont. Whenever it output a display my keyboard light turns on. What can I do now please ?
完成的
Raman multani why would you have to do this "So when I'm shorting the power pins using a screwdriver" Does your power supply not come on with the power button?
完成的
添加一条评论
1个答案
已选择的解决方案
@Raman multani
Try resetting the BIOS back to default by using the CLRMOS1 jumper as shown on p.24 of the user manual
Try connecting a system speaker (see image) to the header pins (see p.26 Chassis Intrusion and Speaker Header 7-pin SPK _ C I1 -see p.6, No. 11) and listen for the beep error codes when starting. (red wire to +5V pin)
The following are AMI BIOS Beep error codes that can occur.
Number of beeps:
1 beep - short Memory refresh timer error.
2 beeps - short Parity error.
3 beeps -short Main memory read / write test error.
4 beeps - short System timer failure.
5 beeps - short Process error.
6 beeps - short Keyboard controller BAT test error.
7 beeps - short General exception error.
8 beeps - short Display memory error.
9 beeps - short ROM BIOS checksum error.
10 beeps - short CMOS shutdown Read/Write error.
11 beeps - short Cache Memory bad.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Raman multani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 114
