跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Home button not working after screen change
I changed the screen on my phone. The original home button works fine with the original screen. It does not work with replacement. When i power it on it does not pop the unable to activate home button etc warning at all. in settings i can go into fingerprint section and select add print, but it does not register. home button does not work. Is it the home button cable on the replacement screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The home button flex cable from the screen to the logic board will have a small tear. This usually happens at the 90 degree bend and might be hard to see without magnification. Your only solution is to replace the screen.
这个答案有帮助吗?
得分 1
1条评论:
it does seem as if it is the screen, as i stated the button is fine, so is the phone, as it works fine with the original broken screen.
完成的
添加一条评论
最有帮助的答案
I have had this issue in the past. The home button on the iphone 7&8 are not a actual “button”, they are just touch sensors. The only real way to keep your home button working is to switch over the original when doing a screen replacement, if not you will loose all functionality of the button. I replaced a screen on a 7 and switched over the home button, but the button didn’t work at all. I switched over the metal heat shield that has the original home button flex cable into the new screen and it started working fine. I also made sure that the bracket and the button itself were all aligned and tightened. Hope this helps, good luck!
这个答案有帮助吗?
得分 1
2条评论:
Also you may have damaged the extension flex cable and the flex cable on the home button. Check for any small tears, they are extremely fragile.
完成的
As i stated, the button works fine with the original broken screen. it is not possible to use the home button cable from the old screen as far as i know.
完成的
添加一条评论
添加你的答案
sam caspian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
