跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
MacBook doesn't run on battery.
Bought last year, no liquid damage. Every time i disconnect the charger from my MacBook it turns off, and cannot run solely on it’s battery. I’ve tried PRAM reset, SMC reset and the battery status is normal and a cycle count of 28. Is there a solve to this? Battery now slowly depleting, at 21%.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Let's check things out, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
Here you go. :)
完成的
Is the battery a third-party or a original one from Apple?
完成的
How can I tell?, probably third party I have no idea.
完成的
The battery is only a little over a year old. When you have Coconut Battery open, click on the box that says battery to get more info on it. It shows it is connected but not charging.
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
What I see is the charger is connected by the charger is not charging the battery (0 Watts)!
It this point this is looking like a logic board problem with the charging MOSFET’s and/or SMC logic is not turning them on.
This will require deeper skills as you need to find someone with the tools and access to the needed parts to fix your logic board.
这个答案有帮助吗?
得分 1
2条评论:
So what can I do?
完成的
Find someone with the deeper skills to fix your logic board. Do you have any independent Mac repair shops near you? This is beyond a DIY without the schematics and board views, the ability to read them, having the needed tools and access to the small SMT devices which are on your logic board.
OR... Replace the logic board
完成的
添加一条评论
添加你的答案
The BattleBeast2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 115
