跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 个问题 查看全部
Why is my iMac screen dim and/or stage lighting?
Hi everyone!
So, I’ve been plagued by a dim screen/stage lighting issue with my 2017 27” iMac. I first noticed how dim my screen was a couple of months ago. The brightness adjuster wouldn’t start affecting anything until it was below 50% of the adjustment bar. So, my iMac was essentially just running at half-brightness. I noticed in some darker UI programs, that there was some severe stage lighting going on. I was to the point where I was about to order a new LED logic board (well, maybe not order bc I couldn’t find ANY in-stock)… However, I found that resetting my NVRAM would buy me a few days of blissful, easy to work with, full screen brightness. This leads me to believe that it’s some sort of software issue. At one point, this reset worked for works. Now, I have to do it every three or four days.
There’s SO much info on stage lighting for MBPs, but barely anything for iMacs. Even less for NVRAM seeming to temporarily fix the problem. Any insight into this would be monumentally appreciated as this is my main machine and I’d love to have it performing as it should be. Thanks!
PS: Not sure if this helps or not, but I can’t help but pin the correlation that this started happening right around the same time that I started using Adobe AfterEffects. I’ve since ceased using it on my iMac. I’m running macOS Catalina v.10.15.7 too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Has your system been opened for service or enhancement?
完成的
@danj it has not.
完成的
添加一条评论
1个答案
最有帮助的答案
Sadly, I don’t have schematics or board views for this system, I’m suspecting the backlight connection is the likely area, either on the panel or the logic board. The LED driver logic would more likely fail outright than part way.
Basically, the backlight LED’s within the display are grouped in three sets interwoven so it appears to be stage lighting as one or two sets are not lit.
这个答案有帮助吗?
得分 1
2条评论:
Hi Dan! Thanks so much for your reply. Yeah, I've thought it could be the connection (similar to how the stagelight ridden MacBook Pros were affected). However, is there anything you can think of that would cause it to go back to normal after resetting the NVRAM? If it's hardware, should resetting NVRAM affect it at all? This is all beyond my usual Mac repair knowledge. Thanks!
完成的
Loose connection is the issue. Resetting SMC or NVRAM won't effect this.
完成的
添加一条评论
添加你的答案
Gray 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 363
