跳转到主内容
Does all WD Green SSD come with SanDisk Chip?
I just saw a cheap WD Green SSD on some e-commerce website. But someone in the review section says, inside the SSD, it doesn’t contain “SanDisk” labeled chip. Is that fake? or there can be genuine WD Green SSD(s) without “SanDisk” chip?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I’m not sure I follow your question, what I can tell you is SanDisk is part of Western Digital as of 2016.
Even still Western Digital may buy chips from other vendors to create their products besides SanDisk. These maybe controllers and support chips. Its also possible the flash chips are not marked with a vendor ID in the image.
So is your drive real or a knockoff? Without more information its hard to say.
这个答案有帮助吗?
得分 1
1条评论:
Thanks you!!
完成的
添加一条评论
If the price is too good to be true then it probably is not a good choice.
Shop around and compare.
这个答案有帮助吗?
得分 1
添加一条评论
Not necessarily fake. WD (Western Digital) owns SanDisk, so many WD Green SSDs do use SanDisk-labeled NAND chips-but not always. WD sources components based on availability and cost, so it's possible to get a genuine WD Green SSD with NAND chips from other suppliers, or unlabeled ones.
As long as you buy from a trusted seller and the packaging, serial number, and performance check out, it’s likely genuine-even without a visible SanDisk chip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhaiminul Islam Ninad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 41
总计 1,673
