跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone not recognized by pc but charges with wall charger
I have an iphone 6 that charges with a wall charger but it won’t be recognized by a pc when plugged in. I tried multiple computers/cables and also replaced the charging port but still no luck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Are you using original apple cables. If you are it could be a fault with the board like tristar or Tigris ic’s
完成的
Yes, original cable.
完成的
I did more research and it appears others are saying it's a bad tristar chip so I will chalk it up to a bad tristar.
完成的
添加一条评论
1个答案
Uninstall and re-install iTunes and plug your iPhone into a different USB port. That should help.
这个答案有帮助吗?
得分 0
4条评论:
I don't think it's itunes as my other iphone is detected just fine and there is no difference when using a different usb port.
完成的
@ntec May I know if you've just encountered this issue only recently?
完成的
@v3nuo This is not my phone so I don’t know. It appears the tristar chip is bad so I will leave it at that.
完成的
@ntec OK, please keep me posted, thanks a lot!
完成的
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 43
