iPhone not recognized by pc but charges with wall charger
I have an iphone 6 that charges with a wall charger but it won’t be recognized by a pc when plugged in. I tried multiple computers/cables and also replaced the charging port but still no luck.
Are you using original apple cables. If you are it could be a fault with the board like tristar or Tigris ic’s
由 daniel 完成的
Yes, original cable.
由 John Nguyen 完成的
I did more research and it appears others are saying it's a bad tristar chip so I will chalk it up to a bad tristar.
由 John Nguyen 完成的
