跳转到主内容
Repair guides and support for the third-generation 5D, a DSLR camera released by Canon in 2012.
18 个问题 查看全部
Water damaged dslr. What would you recommend?
I am thinking about repairing a water damaged 5d mark iii that I saw while browsing online. In the description it says that it will not power on. When I’ve repaired water-damaged phones, it’s usually been the charging port or battery that needs a fix/replacement. What parts in a 5d iii may need a fix/replacent?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @houb ,
What parts have been affected would be unknown until it was opened and inspected as to what damage has occurred. This is the risk you take when buying water damaged devices.
It may be minimal or extensive. Not powering on does not give an indication of what else may be wrong. Before buying the camera, you might try asking the seller a few questions about the camera’s condition e.g. has it been opened and checked for damage by them or not, i.e. have they been trying to fix it themselves and gave up which can affect a lot of things if they weren’t careful, how long ago did the water damage occur, (the longer it has been the more possible corrosion damage there is) etc and base your decision on their responses and your gut instinct.
If you decide to risk it then once you have dis-assembled the camera you will have to clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives scents and is not as effective. If you do have to use it, check the label to verify the amount. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. Also if it has been a while most probably the battery will have to be replaced as even if it hadn’t been affected by the water it may have become depleted beyond recovery.
Once you are satisfied that all the corrosion has been removed and the camera re-assembled, then you can proceed with finding out what works and what doesn’t. It may be unwise to just fix the most obvious problems and then apply power to the camera to test it without making sure that there are no other problems lurking elsewhere first
Here is a link to the ifixit Canon EOS 5D Mark III guides which may be of some help. There is also a parts catalogue (scroll down to Documents section in the link), which may come in handy.
I’m not trying to put you off at all, but you’re the one that’s taking the risk. I hope that it is just a simple fix.
这个答案有帮助吗?
得分 3
添加一条评论
It’s really hard to say what part most likely have been water damaged, it may be almost everywhere in the device or just a connector.
Buying water damages devices is a gamble, you may get an easy one that needs a little bit of cleaning on one or a few places. Or it may be water damage almost everywhere and a lot of things that need a replacement.
What part that is most likely the place where it’s water damaged is difficult to say since it’s not really made to stop water from coming into the device, so it may have got to a lot of different places depending on how much water it was.
Hope this helped, even though I didn’t really give you a clear answer. :D
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Houston Beckworth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 583
