跳转到主内容
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
25 个问题 查看全部
Bowl loses water after flush
I have a new Niagara toilet that I installed. When I flush, everything seems fine. There is no leak, no odd noise, or anything else. After the tank stops filling, the water level in the bowl slowly drops. It loses about 50% of its water. This is strange because after the flush the water level initially settles at the right spot. The tank looks to have the correct amount of water in it after the flush, and even after the bowl loses its water. And the toilet that was there previously didn’t do that. And none of the other new toilets do this (we have two other toilets like this in the house). Any ideas as to what could be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check the air vent, it may be blocked preventing the plumbing system from breathing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 60
总计 3,641
