跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Power and display question?
Ok folks... I have an iMac a1224 with no power to the LCD. External monitor does not work either. I have replaced the following:
Hard drive (currently blank until I can see to install OS)
Power supply
Graphics card (yes it can be replaced. It is not soldered to the logic board.)
Logic board
At this point I will not fail if I have to replace every darn component in the thing. There is no power to any of the USB ports or the external display port.
Led 1, 2, and 3 all come on but never #4.
Anybody have any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I think I am going to start with the power cable then move on to the inverter unless anybody has a better suggestion. Is it possible for the power cable to go bad?
完成的
I have now replaced every major component in the darn thing and it still doesn't work. There doesn't seem to be any power getting to the LCD or the external ports.
完成的
添加一条评论
1个答案
已选择的解决方案
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be • ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
这个答案有帮助吗?
得分 3
2条评论:
LED #4 doesn't turn on. Also seems there is no power to the external ports such as USB or external monitor. I assume the inverter doesn't play a role in external display.
完成的
The inverter has nothing to do with an external monitor and helps to isolate the problem. My answer is a quote from Apple, not my opinion.
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 905
