跳转到主内容
Repair and troubleshooting information for the HP Envy x360 m6-w laptop computer.
9 个问题 查看全部
Hinge repair for hp envy x360
Can I tighten the hinges to my hp envy x360 on my own or is it an hp issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The problem with a lot of consumer laptops from HP is loose hinges are usually caused by the LCD housing being fatigued, and the plastic standoffs may be physically loose/failing so check for that to quickly know for sure - this is not an HP issue; rather a consumer grade issue. But yes, HP seems to be worse then others. That said, you can usually check the screws on the palmrest, and LCD assembly as well as it can sometimes be a tightness issue.
If it’s okay and it continues to be an issue, the hinges are wearing out. Tightening them will help, but it’s better to replace them with new ones at that point. Refer to the HP service manual for disassembly instructions.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joseph Sheehan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 3,633
