跳转到主内容
This HD video recorder contains an excellent camera mode that records and detachable stereo microphone capsules.
7 个问题 查看全部
Why does my Q8 Camcoder suddenly turn off during my recording?
My Q8 Camcoder sometimes turn off when I was recording. I checked the battery and SD card spaces they all look perfectly fine. It is not a problem caused by battery and storage space. I could not find the reason why the camera suddenly blackout during my recording process which makes me very frustrated, and I cannot make a complete recording since I can not predict when it’s going to be dead.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I try recoding my band and the camera shuts off after (Approximately) 45 minutes. I can't even film a whole set. Very disappointed in this camera. Would not recommend anyone to buy this camera at this point.
完成的
添加一条评论
1个答案
This is due to a limitation of the .mov file, which the Q8 and Q4 use to record. The maximum size a .mov file can be is 4GB. Once this limit is reached while recording with the Zoom camcorder, it will begin a new file to continue further recording , if this does not happen check in the settings to see if you can continue recording after it has reached the 4gb file size.
这个答案有帮助吗?
得分 0
1条评论:
What settings? There is nothing in the settings menu to adjust this that I can see.
完成的
添加一条评论
添加你的答案
Dailin Zeng 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 14
总计 600
