跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 个问题 查看全部
Fridge compressor kicking in and out, can generator power be source?
Lately, I notice more and more condensation on the shelves suggesting this has been ongoing. I brushed off the coils on the back ( not much dust) unplugged and reset to zero. After plugging in it’s working again. I set the temps in the middle ( 0-7) and its cooling and freezing. I can’t hear the freezer fan which makes me believe it hasn’t been working since the foods on the top shelf don’t freeze properly. This is a Frigidaire FRT125GWK. The back and compressor area look pretty clean, so I don’t think its that old. I run my cabin with a Firman 4550 W generator into my breaker box. When I bought the cabin it was run on a 2500 W gen and condensation was a problem. I run a 10 cu.ft. freezer,, 1200W microwave, a propane range requiring elec for oven, coffee maker and 3/4 fridge. Only the fridge has seems to have issues. Should I have my fridge on a surge protected power bar? I have to shutdown for oil inspection. Can start up surge affect fridge running W r only 3650? Last eve my microwave (2nd time) needed to cool down after 4 min cooking (it bumped off, its on surge protector bar)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Set the thermostat to a lower setting to see if the compressor starts and then stays on. If it does, the compressor doesn't have a problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paul Hogan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 370
