跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Why does my iPhone keep randomly switching off?
I have this problem with my iPhone X where throughout the day, even at say 53% battery left, it randomly switches itself off. I wouldn’t mind so much if I could just switch it back on but the issue is that I can’t switch it back on by it’s own power, it has to be plugged into a power source, whether it be a PC or by a plug socket. Any ideas what might be causing this issue? I had thought of possible a faulty battery connector but if I switch it off normally and then switch it on normally it’s fine. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would take a look at the maximum capacity in the battery health tab. Typically when it gets below 85% is when I recommend a replacement as that’s roughly when people notice battery trouble. But it could be an issue with the port as well. The iPhone X and above are picky when it comes to charging ports. If it’s not connected, functioning properly, or it was replaced with an aftermarket port, it can cause issues like this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Frost 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
