跳转到主内容
加入维修社区 - 创建账户
7.9 英寸显示屏 / 型号 A1432 / 提供黑色或白色版本 / 2012 年 10 月 23 日发布 / 16、32 或 64 GB 容量
Screen Unresponsive after getting my cracked iPad mini fixed
My iPad mini was cracked and sent it to get fixed when I got it back it wasn’t responsive. This was around 2-3 years ago. Now I decided to see what’s going on with it and ruled out a possible issue the digitizer isn’t working and a question came to mind since I don’t know whether the screen behind the digitizer should be functioning when I touch it or not sorry for the noobie question. So 2nd question is whether I need to replace the digitizer and the screen behind it..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
So the digitizer doesnt have anything to do with the touch screen since the digitizer is what gives you the display while the lcd aka the touch screen is what provides the touch, so if you are getting a display then that means your LCD is damaged and needs replaced, I was basically just first defining the two things for you even tho you said you rules the digitizer out. But yeah also there isnt a screen behind the digitizer, the digitizer is behind the lcd which is the touch screen so thats what needs to be replaced
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joey Vasquez Vasquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 410
