跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
replacement part for the sleep switch
Does anyone knows from where do I get the sleep slider for a n2ds? I bought a 2ds from ebay and the sleep switch was melted so I need to solder a new one on. or does anyone knows the serial number or something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i believe the serial number is on the back of the device if not, you can find it in the settings and under a tab similar to about device, and im not too sure if you can actually buy parts to this but if so amazon might be your best bet
这个答案有帮助吗?
得分 0
1条评论:
I know where to find the serial number of the console itself. But I need this special switch/slider for the sleep switch/slider (however you want to call it)
完成的
添加一条评论
添加你的答案
Rocco Patzke 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 14
总计 95
