跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
iPhone 8 plus not charging, but wireless charging after housing swap
Hi, i did a housing swap for my iPhone 8 plus, and everything seems fine, but i can’t get it to charge with the charger wired, wirelessly it charges fine but when i plug it in it doesn’t charge. when the phone is ran out of battery and i plug it in the battery icon shows its charging, and if the phones off with battery and i plug it in, the apple logo shows but i can’t get it to show as charging without wireless charging when its actually on. can anyone help? thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
So what most likely is your issue, is that you damaged the charge port its self, it can be replaced but thats what your issue is to my knowledge. another way you can check too see if that is the issue check the microphone and see if that works and if the loud speakers work, if neither of them work as well with the charging then you need to get a charging port replacement
这个答案有帮助吗?
得分 1
添加一条评论
Was that backhousing a new one with preinstalled dockconnector? Otherwise take out your old dockconnector and try that one,
这个答案有帮助吗?
得分 0
2条评论:
ive tried different dock connectors and still the same issue!
完成的
take a look at your logic board especially around the battery connector maybe a small component was knock of?
完成的
添加一条评论
添加你的答案
lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 253
