跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Screen wobbles back and forth when open
My 2015 Retina MacBook screen wobbles back and forth when I have the laptop open. There is nothing wrong with the display, it’s the half of the laptop that opens up on the hinge. When it opens, the lid will fall half an inch forward or back depending on the angle it is at. It makes a little squeaking sound as well when it moves. Again - nothing is wrong with the actual display/picture of the laptop. It is the actual metal part, if that makes sense. Sorry about the bad description.
Ideas on how to fix this? Anyone else have the same problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like you either have a loose screws holding the hinges or you need a hinge(s) replacement.
Follow this guide to inspect the screws: Retina MacBook 2015 Display Assembly Replacement In Step16 you can see the screws just below the board. The other side has two more screws are they loose?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ryanta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 54
