跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 个问题 查看全部
Replacement VVT solenoid won't fit.
2006 nissan altima SE 2.5L L-4. Pulled the code at AutoZone, “VVT in ‘advanced’ mode for longer than a set time.”. recommendation was to replace the VVT solenoid. Purchased a replacement solenoid at AutoZone. Removed the old solenoid, tried to install replacement but it won't seat fully. Upon inspection the distal ends of the two look different and the replacement will not fully seat, sticks out a couple of mms.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@msabo at this time the only thing to do is to return the one you purchased and get the proper one. Take the old one and compare it at the store to ensure you get the right one.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matt Sabo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 162
