跳转到主内容
联想 Chromebook 维修指南。
124 个问题 查看全部
Why is my chromebook not working #2?
Before my chromebook stopped working, It would sometimes just randomly go on a black screen and if you tapped it gently it would go out but then one day it just went on the black screen and you couldn’t use it. No matter what you can’t see anything on the screen, it’s just pure black and we can still see a bit of light coming out of it but everything is black and you can’t do anything on it. Also when we charge the chromebook, the battery color is red. I hope someone can help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
ok so what happened is you are having a backlight issue with the lcd, your backlight has gone out so you will need to get the screen replaced. but before you go to that have you damaged it at all?
这个答案有帮助吗?
得分 0
9条评论:
The screen is broken a bit.
完成的
so yeah your backlight got damaged and thats why its not working
you will have to get your screen replaced
完成的
how much would it be to fix it?
完成的
depends, on the year, if its touch screen, and model, and as well how much the repair shop would charge you
完成的
if its touchscreen it will be more expensive
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Turbo Cap 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 100
