Camera not working, showing yellow flashing on sd card
hi soon as turn the camera on ,i cant record or take pic sd card is showing with yellow triangle /got from las vegas not even used once sd card is 16bg bran new one.
You most likely need to format your sd card in the camera. When you buy them they are blank to be able to work in any device. Insert the card in your camera, go to menu and scroll through until you find image storage, then chose card, then format or something similar to that series of options. should be about 1 minute of your time and then it should be up and working again. Good luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 892
