跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
What is this chip by the lvds connector a1502 early 2015 MacBook Pro.
I bought this MacBook Pro 13” early 2015 with a screen that looks like a bad TV channel with interference. Could this chip by the lvds connector be the cause? It’s damaged. I have another late 2013 a1502 with a similar chip. Is that compatible?
Update (09/29/2020)
this is what the screen looks like. The seller said it just stopped working. When I opened the case I noticed the damaged chip.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What does an external monitor show you?
This is tricky! If the video signal is messed up on the HDMI port and the Thunderbolt/DP ports (check both) then the issue is within the logic board.
If its clean on the external display on all the ports the internal displays T-CON logic is damaged which is part of the display assembly.
完成的
The output to the HDMI was pretty much blank. Probably not worth fixing this one. The kid said it worked fine hooked up with the HDMI. I thought it might have been as simple as a lvds cable. Buying broken laptops is always a risk.
完成的
添加一条评论
1个答案
This is an inductor coil L2920
While the ferrite element is damaged I don’t see this is the cause of your display issues. Can you post a few pics so we can see what you are seeing.
这个答案有帮助吗?
得分 0
2条评论:
Thanks Dan. I wish there were classes out here on board repair. I wanted to take the class Jessa had at iPad rehab in New York but Covid hit, had to put off my plans to attend.
完成的
Sorry it didn't work out. Don't forget to score the answer and accept it, thanks!
完成的
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 163
