What is this chip by the lvds connector a1502 early 2015 MacBook Pro.
I bought this MacBook Pro 13” early 2015 with a screen that looks like a bad TV channel with interference. Could this chip by the lvds connector be the cause? It’s damaged. I have another late 2013 a1502 with a similar chip. Is that compatible?
Update (09/29/2020)
this is what the screen looks like. The seller said it just stopped working. When I opened the case I noticed the damaged chip.
What does an external monitor show you?
This is tricky! If the video signal is messed up on the HDMI port and the Thunderbolt/DP ports (check both) then the issue is within the logic board.
If its clean on the external display on all the ports the internal displays T-CON logic is damaged which is part of the display assembly.
由 Dan 完成的
The output to the HDMI was pretty much blank. Probably not worth fixing this one. The kid said it worked fine hooked up with the HDMI. I thought it might have been as simple as a lvds cable. Buying broken laptops is always a risk.
由 Brian 完成的
