跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
175 个问题 查看全部
Switch lite water / tea damage - is it possible to fix?
I spilled tea on a table that had my switch lite on, and immediately dried it up with paper towels. Initially there was no response from the switch but now it seems to just be the screen which isn’t responding.
I can hear the rest of the console responding to button presses. I’ve had the switch in a warm room for 4 days now, with no change in screen response.
Any suggestions welcome as Nintendo seems to consider liquid damage a breach of warranty.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @bonkingmadsnek
The water/tea causes corrosion and provides circuit paths for the electricity which were not in the console’s operating design and could damage the components. The corrosion starts immediately and doesn’t stop until it has been properly cleaned away.
Do not try to charge or to turn on the console and then remove the battery as soon as possible so as to minimize any further problems.
Next you need to disassemble the rest of the console and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb, be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Also remove any shields that may be covering some components and clean there as the water may have got in under them as well. The ends of any cables and the connectors need to be cleaned as well.
Hopefully after you have done all this the console might possibly work correctly again.
Here is a link to the ifixit Nintendo Switch Lite teardown guide. This will help you to open the device and inspect and clean as required
If this process seems too daunting, I suggest that take your console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
这个答案有帮助吗?
得分 3
4条评论:
Thank you for such a quick and detailed response. I've just ordered products so fingers crossed I get into it in time and am able to repair it.
完成的
@bonkingmadsnek
If possible whilst you're waiting for the products, open the device and disconnect the battery to at least minimize any further damage
With most devices these days the power button is not a power isolating switch so there is always power available at some points on the motherboard when the device is off. Think of the device as being in an extremely low power state rather than being completely off.
Good luck with the repair
Cheers
完成的
Unfortunately one of the products is the tri point screwdriver that I need to open it - unless you have any tips to get around that? I have the tiny phillips one for the other screws
完成的
@bonkingmadsnek
Unfortunately no. Not without causing more unnecessary damage
I think that it is better then to just wait. Not turning it on anymore etc will definitely help.
完成的
添加一条评论
添加你的答案
Tara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 26
过去 30 天: 100
总计 12,160
