跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Dropped my phone now I can’t hear my calls or video chat
My sound works and so does my front camera. Everything works barley a crack but I can’t hear whenever I answer my phone calls and I can’t put it on speaker. Also when I get a video call, once I answer it automatically says “call failed” , why is that??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You need to determine if it is a parts problem of a component on the logic board.
·         Can Siri hear you?
·         Will voice memo let you record?
If voice memos will not let you record you most likely have the signature audio IC fault which occurs on the 7 series. This repair requires microsoldering.
If voice memos let you record and Siri can hear you I would start by replacing the dock connector. and front speaker flex assembly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kenya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,074
