跳转到主内容
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
59 个问题 查看全部
My Samsung A5 2016 only turns on for a few seconds
It can only turn on while plugged into the charger, but it only turns on for a few seconds before shutting down. It can’t be turned on by pressing the power button, and while it’s plugged in it says that the battery is 100% charged but that wasn’t the actual percentage before this happened (34%). When I managed to turn it on and unlock my phone and removed the cable, the device just shutdown like when it reaches 0%. Is this a battery problem or something else? It’s been stuck like this for a few days and I need help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @cortisol ,
I suggest that you replace the battery and then re-evaluate the problem. It may be that a faulty battery is causing problems with the normal operation of the phone when the charger is connected.
Here’s the ifixit 三星 盖乐世 A5 (2016) 电池更换 guide that may help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Isabel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 169
