跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Problem with battery replacement
Hello. I bought a replacement battery for the iPhone 3G in your store, but after replacing the iPhone says it is very hot and gets an exclamation point on the screen. I've tried to take back and neck by four times, but did not work (problem persists). iPhone does not work with this battery. Replace the old battery, and the iPhone works normally (although for a few minutes).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
exclamation mark sounds like the temp sensor on the battery connection...send it back.
完成的
添加一条评论
1个答案
已选择的解决方案
I have been fixing iPhones for almost a year now, and from my experience i have found 3G/S batteries to be VERY dodgy. Regardless of who you buy the battery off, for some reason there is a high percentage of faulty batteries. Whether it be the logic board's damaging them upon installation (static discharge or other electrical causes) or purely because they are made from a poor design, its all about the luck of the draw.
Make sure that when you replace the battery again next time that you are not around objects that can create static (carpet or other friction surfaces), or you can invest in an anti-static wrist strap that earths you, that will do the job too :)
Anti-Static Wrist Strap - Anti Static Wrist Strap
My advice is to send back to the iFixit team and request for a replacement. They shouldn't have any problem with that :)
Help protect your electronics from accidental electrostatic discharge (ESD) damage during repairs. Ground yourself while working.图片
产品
$7.95
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
vanderjunior 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,098
