跳转到主内容
加入维修社区 - 创建账户
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
My psp doesn't charge
The psp doesn't charge when i plug the charger in
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Have you tried a new battery yet? If the battery isnt the problem the next step is to open the case and make sure that all connectors are in place. If they are, unfortunately you may need a new logic board.
完成的
添加一条评论
1个答案
已选择的解决方案
Ali, if you checked the battery and all the connectors as well as contacts as Phillip Takahashi suggested and it still does not solve your issue, you might want to take a look at the logic board fuse. Great information on the fuses etc is available here and of course here with the instructions. Give this a try before you buy a new logic board.....;-) Should you be really bored and you like to learn more about this, you can download the BOARD SERVICE MANUAL 1st edition Level 3 from here :-)... good luck
这个答案有帮助吗?
得分 2
1条评论:
is this a psp 2000 or 3000 board?
完成的
添加一条评论
添加你的答案
Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 3,485
